- Nov 3, 2010
- 96
- 18
- 83
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi,
I'm pricing up a job at the moment that includes about 36 LED downlights to be installed mostly in kitchen dining areas.
I was wondering if anyone has an opinion which is better to install for the customers sake, either standard GU10 downlights with LED (dimmable) lamps or to install the fittings with the integral lamps such as the JCC FGLED7?
i can get the JCC ones at a reasonable price but it does work out a bit cheaper the other way.
and at some point the customer will ask how to change the lamps on the JCC ones and i'll have to explain you cant but have 10 year warranty but i'm guessing your a bit stuffed when they do finally fail.
I'm thinking standard gu10 fittings with replaceable lamps are better in the long term unless anybody can explain otherwise.
thanks for any advice
Cheers
Cheers
