B
Bradders
Hi,
In the past I've replaced MR16 halogen spots with LEDs and had issues getting them to work. I understand this is driver related. This time, I'm having problems switching GU10s halogen with LED. I can't understand this as my understanding is there will not be a driver involved and this should just me normal mains voltage. Any thoughts on what I'm missing?
What's the problem with them.
Where did you source your LED lamps from?
Reactions: DPG
I think some cable has become detached while getting the halogens out.
GU10 LED are a straight swap for GU10 halogen.
However,
There was a post on here a while ago about someone looking for 12v GU10, and the majority said they didn't exist.... Which we were proved wrong.
What i'm saying is, check the voltage rating on your LED lamps.
My thoughts they could have been 12v.
Reactions: Admin
are the ones 12v 240vor other .
Reactions: buzzlightyear
Going to give us anymore info?
Reactions: DPG
Yes. There were 6 lights in the bathroom. Two were LED, the others halogen. When I replaced them only 2 lights worked.
We're they all functional before you replaced them.
Yes. Only once I swapped is there a problem. I know the bulbs are good. The wiring must be loose somewhere.
Are you 100% certain the old lamps were all 230v.
From what I could read on them yes. One the print has almost worn off or wasn't printed on properly.
Sounds like something has broken down whilst you were moving them about. Could be a whole pile of dodgy connections holding them all together.
Reactions: Andy78
Could try putting the old lamps back in, see if the work.
If they do its a lamp issue, unlikely but woth a go.
If they don't then its wiring,
If theyre loop in loop out wired and none of the lights work the issue probably lies at the first fitting, loft unfortunately.
Reactions: ruston
LED Gu10s to replace Halogen lamps not working
Lighting Forum
Bradders,
Toneyz,
