Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs but they do not illuminate when the switch is turned on. The halogen bulbs work just fine. Am I missing something?
Philips CorePro 17.5W 118mm Dimmable LED R7S
ProLite 10W 118mm Non-Dimmable LED R7S
Any thoughts would be appreciated!
Are these lights on a dimmer? If so, likely the dimmer won't work with the low load of the LED lamp.
Are the contacts in the old fittings nice and clean - no oxide film or corrosion?
Might be worth giving them a scrub with a Scotchbrite pad or equivalent if you can get in there!
SOLVED
So it turns out the reflective backing was just barely blocking the chunky LED from fitting properly against the contacts. Not enough for me to notice at first. I crimped the backing away slightly to allow the LED to make proper contact and now they work great. Thank you SJD and Avo for your help!
London UK
United Kingdom
R7S LED retrofit not working
Lighting Forum
joliver,
brianmoooore,
