The chances are that this is an end of the circuit on your lights and will have to assume that if your going to move forward.
You say you have 2 T+E cables which is 2 reds, 2 blacks and 2 bare covered with a sleeve either green or yellow/green. This then would make you think 2 reds are lines 1 black a neutral other black a switch line earth the sleeved ones
So isolating from the CU take your switch off the wall, or if it's a pull switch drop it down. You will hopfully see 1 red 1 black and 1 bare with sleeve. Disconnect the red and black cables and twist them together. With a multi meter, I so hope you know what that is, go back to the light and place one lead to each red and black's bare conductors. If nothing changes on the meter, then try the other cable doing the same.
This will then change the meter from most likely the symbol 1 to 0.00 depending on your meter. Once you identify which is the switch cable mark that black with a bit of tape, you should sleeve it really with red/brown but let's not go there.
Your connection then is 2 x red together 1 x black not marked to neutral and balck marked switch line. Earths in earth. Next time though MARK MARK MARK before you disconnect anything
