Discuss Light flicker now and then in the Lighting Forum area at ElectriciansForums.net
Steviecuk
If you've seen my previous thread for advice you'll know that I have just finished doing up my living room and I have 8 dimable LED GU10's fitted into the main socket loop because of a couple of reasons. The loops goes like this...
Fused spur on socket loop -> 13A plug socket -> junction box -> 8x GU10 LED wired in parallel. All using 2.5mm cable.
I have noticed, certainly when lights on full power, that every now and then I get a single flicker from the GU10's. Usually as I plug something into any of the sockets on the loop.
Can anyone tell me why this happens and if there is a way of stopping this. It's not a major issue but would like it to be perfect if possible.
Thanks. Steve.
are the lights controlled by a dimer ?
If so, that is your culprit !
The triggering circuit in some dimers
can be very sensitive to voltage variations.
there's no easy fix, you have to use another brand of dimer.
Hi Steve - 2 things come to mind. Is there a continuity issue in the loop and you're flexing a junction in the back of the outlet (causing a momentary loss of power) when you plug in. This seems unlikely as you say all outlets affected. Or, it may be that the normal current surge on connection of a new load. This current surge causes a voltage drop in the circuit and this dims the light. Lighting circuits have a smaller voltage drop design allowance in the Standards in recognition the eye can pick up small changes in illumination. If voltage drop is causing this, then you may improve it by moving the lights onto a new circuit. FYI, I try to put lights onto dedicated lighting circuits to minimise this effect. Hope that helps, David.
He is getting volt drop I should imagine. What are you plugging in, a kettle?
Why did you wire them in 2.5?
Don't ask. Lol. I bought too much 2.5 which I used to go to the socket before the lights so I just carried on with it to the lights. I have already been advised I could have put a 5a fuse box after the socket then dropped down to 1.5 but didn't think of it at the time. Things like laptop charger I'm plugging in.
Sorry to resuscitate this thread but still haven't solved the problem. I have now cut two holes in my bloody ceiling and taken the lights off of the socket ring and put it where it should have been, on the lighting one. Guess what, still bloody flickers when I plug something in. How the hell is it flickering when it's on a completely different loop to the sockets? Arrrrggghhhh
Hello there,
What is it you are plugging in, for example a vacuum draws a high startup current resulting in the lights dimming when you switch it on
Is it a constant flicker or as the previous post said just a drop when appliance is used.
Change the dimmer type - check out the varilight range. It was mentioned when you first posted.
I did, last year, have flickering lights all over the house which turned out to be a supply phase gone funky. I only knew this because they cut power in the night to do their thing. No problems since!
That said - CHANGE YOUR DIMMER!
I will I will. I just can't see why the dimmer would make them flicker when the supply voltage on the light ring is independent from the sockets. If they are on a completely different loop, how can they effect one another?
it could be induced voltage from a cable close to the LED cables. a snubber may cure this.
Reply to Light flicker now and then in the Lighting Forum area at ElectriciansForums.net
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi all, just joined the forum, have a weird problem, wondering if I could get some ideas. We built our house about 6 years ago. The downstairs...
