Discuss Light on separate circuit stopped working in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. I’m a newly qualified electrician. Just had a confusing issue. I put up a new light in a clock room for a customer. It’s a microwave sensor light. So I left out the switch live and terminated feed in feed out lives and neutrals.
Now, an upstairs light stopped working. I can’t understand why. So I dropped the new fitting and double checked the cables I had were right. They are. So I connectored them and left the fitting off. Same issue. The light that has stopped working has permanent live at the pendant in loop but no voltage on switch.
like I said it’s a different circuit which is just baffling me. Also a separate led fitting on the downstairs circuit has gone very very dim. Again is this a coincidence or part of a bigger problem.
Would really appreciate some help as I’m at a loss. My background is new build housing and I’ve only recently qualified. I’m massively aware of my limitations but this seemed like a very straight forward job.
Another thing. The main switch seems to crackle when I turn it on.
thanks everyone
Do you have 230V PL to earth but not PL to neutral at the upstairs light.
Could there be a borrowed neutral from the downstairs light that has been misidentified?
My golden rule with this kind of scenario is to leave anything that I have not touched and concentrate my attentions on what I could have changed.
Have you broken an existing neutral, as well as live, at the switch? ( ins and outs, you say)
Are you 100% sure said upstairs light was actually working before you started? For example, could putting the Xmas decorations away in the loft have pulled a cable loose, and nobody has tried using the light since?
Reply to Light on separate circuit stopped working in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
