Discuss *Light switch problem* please help in the Canada area at ElectriciansForums.net
V
verve
Hi
I've just installed under-cabinet fluorescent kitchen lighting that can be switched on/off from a 2 Gang 2 Way Rocker switch that also operates the main ceiling light. However – I can’t turn on the cabinet lights only, without having to switch the main light on.
I would be very grateful if someone could suggest why this is and how I could change this so I could switch just the kitchen lights on only.
Many thanks
A
You have supplied from the cabinet lights from the switched side of the celining light switch
presume you have a link between the two gangs of the switches?
Basically you should have phase coming into common on of the gangs, L1 will then feed ceiling light as switched phase
Link the common to the common on the other gang, then take the L1 of this gang as the switched phase for the cabinet lights.
job done, if you HAVENT got a link there, post bak with how you have wired the cabinet lights from scratch, and i will talk you through it, no probs
Reply to *Light switch problem* please help in the Canada area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
