Discuss Light switch sparking only when off in the UK Electrical Forum area at ElectriciansForums.net
Leigh2909
Hi I’m looking for some advice on a sparking light switch. This is only happening when the light switch is off. When it’s on there is no problem and the lights work fine
I have changed the light switch but this hasn’t helped
What exactly is sparking? Does the light flicker when it is supposed to be off? Does anything trip? What kind of switch is fitted? Are there any other connections such as a neutral loop-through in the back box?
For the switch itself to arc when off, current must either be flowing through it, in which case the light will probably flicker on, or to earth or some other exposed metal, in which case an MCB or RCD in the consumer unit is likely to trip. In any case replacing the switch should have removed the fault.
Pics needed I think...
yes it flickers when it’s supposed to be off
Nothing trips and it all works fine when the switch is on
I think the spark is coming from the socket but I can also hear a buzzing noise in the cupboard behind which contains the fuse box
Another way to describe it might be that it's flickering all the time, caused by the Live and Switch wire shorting elsewhere, maybe in the cupboard maybe the cable in the wall.
BUT when the light switch is on and the light is on, it's masking the issue.
Does it have to be this switch that’s causing the issue as I’ve never touched this one but a couple of others in the same room have recently been moved. These other switches don’t turn the lights on that are flickering
Can you be a bit more specific as to what is sparking and where you are seeing the spark? E.g. inside the switch visible around the rocker.
Who moved the switches?
How were they moved and were any connections hidden in the walls or ceiling?
Sounds like a poorly made off joint somewhere.
Is the lamp an LED? The flashes could be due to capacitive coupling in the cable rather than a faulty switch. If it is an LED and you have an old filament lamp that will fit, you could try that to see if the flashing stops.
The video seemed to have a lot of arcing noises in it, suggesting the live and switch live wires are intermittently shorting.
It looks like the floash is in front of the faceplate. there are shadows behind the faceplate. light2.jpglooks like a camera flash.
Reply to Light switch sparking only when off in the UK Electrical Forum area at ElectriciansForums.net
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
