Discuss Lighting problem. One switch wont work without the other being on in the UK Electrical Forum area at ElectriciansForums.net
Just replaced my double light switch now one switch wont work unles the other is on. I have the main power going in to the com then a wire leading from that into the other com then both circuits going in to the 2 L1 holes. I will try and get a picture up
Picture of setup
One of those cables is live in you would need to find out which one it is first and that goes into the COMMON which links to the other.
Reply to Lighting problem. One switch wont work without the other being on in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
