Family member having this problem.
Upstairs and downstairs are on different circuits.
Every now and then you put the light on at the switch and the bulb will blow and the fuse board switch trips - easily solved by a new lightbulb - but this happens maybe once every 3-4 weeks.
Today in the kitchen the bulbs went but when we put new bulbs in nothing happens - I suspect the switch is broken now (fuse gone?)
Anyone have a view on what the actual problem may be?
Issue seems to be happening across 4 different rooms at least. 2 up and 2 down.
