Discuss Main Earthing Conductor and Earthing System question. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello all,
Just a quick question regarding I+T that I wanted to get some clarification on:
1. I recently went to a job where the incoming cables from the street came up through a metal conduit from the ground and then ran through some metal trunking before terminating in three sealed fuses (which was essentially the cutout). A 6mm earthing cable was clamped to this incoming piece of metal conduit and ran to an MET before terminating.
My questions are: a) is this a TN-S system? b) is the length of 6mm what I would class as the main earthing conductor for the installation.
Any constructive response to this would be appreciated. Thank you.
Hi Spinlondon,
Yes I have. I measured 0.21 ohms so got a normal reading. Would the 6mm earth be what I class as the main earthing conductor? I'm guessing so, in which case it would be undersized for the installation.
I can't unfortunately bigspark17 as I didn't take any. It's moreorless exactly as I described however. I assumed the 6mm cable would be what I would have to use as there was no other earth cables present and there was nothing to suggest that the earthing system was anything other than a TN-S. I was just after clarification really.
Reply to Main Earthing Conductor and Earthing System question. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Hi everyone, I'm nearly on my AM2 test and really enjoy the industrial side of things so I thought I'd learn by asking. I recently came across...
