Discuss Megger 1502/2 or 1552 ?? in the Electrical Tools and Products area at ElectriciansForums.net
Hey sid
The 1552 was the replacement for the 1502.
I believe the only difference between the two is that the 1552 has the automatic RCD test feature i.e you just stand by the RCD and the tester does the rest, no running back and fore.
Cheers.
Megger MFT1502-2 17th Edition Multifunction Tester
Key Features Include:
Combined 17th Edition testing
Guaranteed non-tripping loop test range
Insulation test range: 250V, 500V & 1000V.
Continuity, loop & RCD testing.
Selectable touch voltage
Touch (fault) voltage and display
Calibrated earth loop test lead
Illuminated switch probe
Rubber over-moulded case and lid.
Large easy-to-read LCD
Backlit display and selector ranges
Switched probe facility
Megger MFT1552 17th Edition Multifunction Tester
Automatic RCD testing
cheers.
cheers.
didnt think you got the switched probe with the 1502 :confused:
Reply to Megger 1502/2 or 1552 ?? in the Electrical Tools and Products area at ElectriciansForums.net
Bloody specific fitting megger test leads! I've lost 2 of my megger probes now. I have plenty of crocodile clips and the long, thin, bendy probe...
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hey Is there any fans of Meterel ? What do you think of the one below ...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Bit of a long shot on here but does anyone have a circuit diagram for a Chavin Arnoux CA 6545 5kV tester? I've copied my post on EEVBLOG forum...
