Discuss MICC/PYRO advice please in the UK Electrical Forum area at ElectriciansForums.net
I don't know about you, but I used to take pride in first fixing cables of all sorts, making sure they were clipped nice, entering the enclosure properly, nice an neat, now slap it in know matter, as long as it tests OK and it works, it will be OK, what has become of trafesmen and Women? all gone to pot, I know who I lay the blame on and you don't need me to explain that do you?
….and the fact that testing has been carried out, when it is, shows that it's been someone who should know better. Plenty couldn't care less....or don't know any better.
Ah! Stop moanin'! T*at's life, I suppose.
And therein lies the crux of the problems!!!!!
The number of swa lash ups these days has gone through the roof.
It seems to be every other time I come across some. If they can't terminate the armour correctly it's slice a shroud because they've forgotten it.
I see regularly swa terminated via a plastic stuffing gland with all the wire strands just completely cut off at both ends and just the inner cores shoved up the plastic gland....rough as you like but if the new lot aren't shown how to fit a proper swa gland they won't bother
I saw that with twenty odd bollard lights, on a long driveway to a club, not long ago. No stuffers, though, just swa's taped together in the chassis. It's disgraceful and total ignorance. Only found out after a couple had been flattened by parking experts.
If the person doing the job isn’t going to even bother using the armour and cuts it all off , wouldn’t it be better just to use hi-tiff or even rubber flex...
It's all run underground. If in pipe or duct, I've no problem with Hi-tuff...…..but 300m of rubber flex?..... Do me a favour.:confused:
There is an argument to be made for H07-RNF in this case, the neoprene outer sheath is probably more suitable for a duct that may end up full of water than either hi tuff or swa
If it’s up to standard, fair enough but in this situation with such a long run...and I’m not even sure it’s in plastic pipe, I think I’d be going with swa, installed correctly.
How does length affect the type of cable used? Your post suggested that hi tuff would be ok in a duct but tough rubber flex wouldn't, which just doesn't make sense to me. The rubber flex is likely to have the best long term water resistance if the duct fills with water, better suited to pulling in to ducts and may have slightly better volt drop characteristics.
Yes if it isn't in any sort of containment then SWA would be the best choice.
Sorry for the lack of sense Dave, but I'm talking about this installation (situation). Whose to know how secure the system is. About 30 jointing points, all involving cables through concrete and tarmac into the fittings.....no chance of any slight damage? How easy a pull in?
In this situation, swa.
The lazy sods just saved time and cash, throwing the cable in without glanding.
Reply to MICC/PYRO advice please in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
