Discuss Moving from mainly domestic to commercial/industrial in the UK Electrical Forum area at ElectriciansForums.net
I’m nearly a qualified electrician and I’m looking to change from mainly domestic jobs to more of the commercial/ industrial side. I’m just wondering how difficult will it be and what type of work should I expect to be doing?
For yourself Or for a firm ?
Principles of wiring is still the same just the size of cables , install methods is different. You will need to read up on emergency lighting , fire alarms etc
For a firm mate done a bit of emergency lighting and fire alarm installs, what’s the containment side like does it take long to get used too?
If you can thread a bend and bit of 20mm tube , make off Swa and cut a bit of trunking straight you will be fine : )
Reply to Moving from mainly domestic to commercial/industrial in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m an industrial electrician, so when it comes to DB regs and such my experience on them is a little limited. I need 2 x 16A 3 phase supply...
Hi there, firstly wishing you all good health and happiness 🙂 Just a few questions if you all don’t mind answering for me please.. I’ve just...
OLDBOY
O
Hi, I’m an industrial electrical engineer apprentice working at a wastewater treatment plant, I’ve been really enjoying the job which I’ve been...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi guys I’m at one of the funny times in my career where I can’t decide on what I want to do. I’m wondering if one of you experiences folks can...
