Discuss My first soldering! in the UK Electrical Forum area at ElectriciansForums.net
Its funny you should say that Tel . i went into LIDL for a box of cereal and came out with a gas powered soldering iron . It soldered 3 terminals before the ignitor broke :(
the aldi ones are good. the parkside one i bought was a soldering station with temp. control. the iron was used 4 times then stopped getting hot. replaced with a cheapo iron after cutting off plug and wiring into station. still working 3 years on.
For desoldering on PCBs applying some flux from a flux pen to the joints before desoldering will often help a lot. I've been using temperature controlled soldering stations for the last 17 or so years and wouldn't be without now. I do use a standard 80W iron for soldering larger wires such as shown in Luciens example above as they can dump a lot of heat into the joint so it can be soldered fast before all the insulation starts melting. A higher wattage iron is needed for most modern pcbs that have more than one track layer, some multilayer boards can have substantial amounts of copper in the inner layers for power rails that can sink the heat away. If the joint isn't heated up enough the plated through holes can be damaged when the component lead is pulled out.
My current iron for PCB work is a 130W JBC, a fantastic tool, bit rather expensive...
I used 60W for soldering wire to the needle of multimeter after it has broke. I managed to quickly solder wire before it could melt plastic insulator. If I used 30W it would probably need more time to solder and plastic would melt.
Reply to My first soldering! in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
After my recent, first foray into LED strips, I now find myself needing to repair a pcb where a copper contact has come adrift from what appears...
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
having failed my first attempt at 18th edition exam, does anyone have any tips and tricks on how to study for the exam? being that there is a...
I’d welcome your feed back….! As after 35years doing the job.! Knowing about it for 10years.! I came across my first ever experience of...
