Discuss napit in the Business Related area at ElectriciansForums.net
A
andrewcann
hi all just a quick one was thinking of joining napit just one thing havent done any jobs yet to show was thinking of changing a fuse board would this do for the assment it only that i rent so cant do any jobs at home to show any help would be great full
not sure about napit, most of them like to see two examples of work.. one minor and say one a cu change. they dont have to be at your home could be at your friends etc. give them a call sure they will be happy to help you. dont forget your insurance and have all your test sheets filled in before your assessment
Hi,
Just joined the forum, thought you worthy of my first post : )
Ive just gone self employed and had my first assessment last week with Napit. They only wanted to see one job of mine, which was a full rewire, but a fuse board or part rewire would do i think. We only spent about 20 minutes at the job, most of the assessment was at my house.
We spent about three hours going through different things at home, throughout this time he gets an idea of wether or not your capable of doing your job. He checked through loads of things- past certificates from my previous job, qualifications, knowledge of regs etc. Also had to do a quick test (10 Q's or so). Sounds official, but really no need to worry, all quite informal, he was there to see if and where any helps needed, said passing exams and experiance has already proven your competance. Hes not trying to trip you up! Basicly the more things you have to show him the better, he will give you a list of things to get, a week or so before you see him.
When we finnaly got to the job the asessor took a look at the fuseboard, made me take one of the 2way switches off to check for brown sheathing etc and that was it. I think if you just spend more time making everything really neat and tidy (not that my work isnt normally!) then you've got nothing to worry about.
hope this helps!
Reply to napit in the Business Related area at ElectriciansForums.net
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
