Unfortunately from a distance we are unable to correctly identify which wire does what, since they may have been wired unconventionally in the first instance and the changes made when the switch was swapped could also affect how it is wired.
If we were to specify red goes in load for instance and the red was not correctly identified or connected this could cause danger.
The only way to be sure of which wire does what is to be there to test the cabling.
I would suggest that if you know which wire has which function then you follow the diagram in the instructions, if you do not know which wire does what then you would either need to test continuity for each wire to all lights and switches or ask someone else to do this for you and then follow the instructions with the new knowledge.
