Discuss Neighbours supply cables running through the ceiling void. in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I have been to look at a rewire. The builders have pretty much taken the house apart and I have found the neighbours supply cables hanging above my customers ceiling.
The customers line supply cable comes into the top of the cutout and then another line supply comes out of the top and off to the neighbours. The neutral supply goes into a Henley and then has 2 further cables come out of it, one to the neighbours house and one to the customers meter. This is all going on inside the customers house.
My concern is the braided line and neutral cable feeding the neighbours house which runs through my customers ceiling. It has no protection whatsoever, be it mechanical, overload or earth. It doesnt have any form of isolation and its not even the customers.
Bit unsure what to do here. Is this normal for older properties. Should the DNO be called out to re-route the cable? What type of cable is it, It has a braid around it, does it have any kind of mechanical protection, certainly doesn't look like it? Any advice greatly appreciated.
Here are some pictures, not the greatest quality though.
Can't see clearly but agree with Westward probably polybutyl jute cable. Some is still sound, some is getting brittle these days. Unlike VIR it was intended to be installed without containment, but perhaps not snaking around other peoples' houses. Not sure what the policy is with these gratuitously long looped services though.
Reply to Neighbours supply cables running through the ceiling void. in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Hi all, quick question - I have to replace a lateral supply cable where the existing one runs through the ceiling of the basement flat and up...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
