C
cairns
Hi all, have taken over a 2nd fix right at the end, just turned power on, hob circuit is tripping rcd in split load board, the polarity is correct, have done continuity on l-n-e getting 99.9kohms and 299mohms insulation resistance on the hob supply cable, however when I test between n and the earth bar with the hob circuit earth removed am getting 99.9k ohms and 299mohms, when I do live and earth bar with the hob earth removed am getting 4.1kohms and 0.01mohms on insulation resistance.
I would've thought with this low insulation resistance reading it would get a lower continuity reading wouldn't it? Any people with will help me with there knowledge I would be most appreciative.
