OP
Octopus
Wonder if its a plastic CU?
Discuss New kitchen, live earth fault!! in the UK Electrical Forum area at ElectriciansForums.net
Hi again, kitchen sockets should read kitchen and downstairs sockets, house sockets should read upstairs sockets!!So the upstairs sockets aren't protected by a RCD - why not? The installation doesn't comply with the regs....
Can you post a picture of the fuseboard?
Kitchen fitter did not do any electrical work, electrical company did all electrics.He was a kitchen fitter, you can't expect it to be right when you employ those cowboys to do electrical work.
They did say there was a neutral fault on the upstairs sockets, could this be the reason. Could that simply be a badly wired plug?Im betting there was a earth leakage fault with the upstairs sockets existing, there is absolutely no reason to segregate them away from any rcd protection otherwise... no self respecting qualified competent electrician would do what this 'electrician' has done.
Definitely the reason that needs sorting out.H
See reply below, they mentioned a neutral fault after the cable had been drilled, but the fault downstairs appeared after all the work had been completed.PS I bet he drilled through the upstairs socket circuit hence its not on a rcd
All the cables from the main board, go directly up and into the ceiling cavity, so there will no wiring from the upstairs sockets passing through the kitchen.PS I bet he drilled through the upstairs socket circuit hence its not on a rcd
also to note, they haven't balanced the lighting across the rcd's so next time a lamp pops the whole house lighting is possibly effected.
don't know how to fill out the Certificate correctly.
Reply to New kitchen, live earth fault!! in the UK Electrical Forum area at ElectriciansForums.net
