Discuss New light fitting help dual cables in the Lighting Forum area at ElectriciansForums.net
Aslan
Hi,
In my bedroom there's two lights which are controlled by a single switch. I'm in the process of changing the light fittings, one has been done and is fine. The other one has two sets of neutral, live and earth cable with the new light fitting only taking taking live and neutral. I've put in the two live into the live hole and same with neutral and put the neutral into a terminal block.
Trouble is the light doesn't work whilst the other one comes in this one doesn't.
Any help would be appreciated
h2kAZ6
1515938593115148486848 - https://ibb.co/h2kAZ6
Is there a switch for that individual light? If so does the breaker trip when you operate it?
Edit: Answer is in the original post - my bad
Reply to New light fitting help dual cables in the Lighting Forum area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
