Discuss Two cables one box in the DIY Electrical Advice area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had two bulb sockets and was wired with a hot wire to each socket and the neutrals connected and capped. My new fixture has only one hot and one neutral wire but I can’t figure out how to properly connect the fixture. Please let me know if you can help!
Are you sure that it’s 2 hot wires ? It looks like 1 cable is live and the other cable goes to the next light, so tie the blacks together and tie the whites together plus the grounds together and hook up your light. Black to the 2 blacks and white to the 2 whites plus the ground the same way.
Reply to Two cables one box in the DIY Electrical Advice area at ElectriciansForums.net
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
Hello. I hope everyone is safe and healthy. Please see the attached photos for reference. I have a ceiling with a junction box or maybe it...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
I was wondering if someone could assist me in determining whether I can replace my current 3-way switch configuration with an Enbrighten smart...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
