Discuss Only 2 brands for domestic type A rcd/rcbo + type 2 spd in board?? in the Electrical Tools and Products area at ElectriciansForums.net
Mattja
Looking around I'm wondering if I'm going mad. Would have thought type 2 spd next to main switch and type A (not type AC) rcd/rcbos would be the standard everyone should be looking for now (even if it's just recommended and not strictly required in domestics). But only Wylex and Schneider seem to supply the parts?
Anyone else found a supplier for both these features from any other brands or is this it?
Hager do it.
In fact they have made Type A RCCBs and RCBOs for very many years indeed. However these were not common in the UK in the past. The UK is years behind much of the world in this regard.
Cheers, a shame that it's Hager. I refuse to buy a Hager board until they stop mucking about with those stupid rectangular knockouts. Every other brand I've used has standard sizes of circular knockouts that grommets and glands can fit into, just Hager that insists I waste time and materials terminating SWA in a separate enclosure and worry about having enough cables through each side/top/bottom knockout to fill the hole enough for IP rating and then mess around with intumescent sealant when I should just be able to put an intumescent grommet/gland in there and be done with it quick and neat!
And yes it's bizarre isn't it? They do these parts for many other countries, surely it can't be that hard for manufacturers to put existing components into a form that fits UK boards.
You can get Hager boards with circular knockouts and without any knockouts.
Hager don't insist that you waste time or materials, they supply boards with rectangular or circular knockouts or with plain sides. If you order boards with rectangular knockouts it's hardly their fault.
As for intumescent sealants, why would you need them?
I've only found them with rectangular knockouts going into wholesalers and looking at pictures on webpages. If they're not displayed or advertised with circular knockouts it's their fault that I'm assuming they're all with rectangular knockouts. Good to know they can be found somewhere, cheers, but hardly an unfair assumption on my part.
As for sealants, if I'm putting up a metal board that's meant to contain a fire then surely it's good practise not to leave holes in it, and if I'm going down that route, best go intumescent so I'm not wasting time. I'm not having a go if you're not sealing it up, your choice, but I think it's better to do so (and for round knockouts it's as quick and easy as pushing a grommet in).
Its not their fault that you haven't properly researched an dspecified the equipment you will be installing, if you are designing the installation then you are responsible.
Why is it meant to contain a fire? Metal CUs don't have any fire rating or type testing for containment of fire.
ESR also do a type A RCD and at a reasonable price. I think Chint do a type A also, although i would not buy Chint as I believe they fail more often than most RCD's.
Hi MCG offer a type 2 & 3 combined SPD for a good price (£48 inc vat) single module you can get from CEF,
I have found these to be very good value.
Hi,
Looks like this thread is a few months old but ,
I use a the “Fusebox” boards( consumer units ) now for all my installs , THey have type A rcbo s and a type 2 SPD built in next to the main switch , solid board and only £12 per rcbo
£120 all in for 8 way rcbo and SPD .
Hi,
I’ve heard ( happy to be corrected) that fuse box have no ocpd for their SPD over than using the DNO fuse ( no internal ocpd on the SPD either) , for this reason I wouldn’t use them if wanting an SPD in the board.
Hi Ian,
Yes you are correct in saying their is no internal ocpd but they are rated at 125a which for most domestic installs with 60 and 80amp cutouts, the DNO fuse is acceptable for last resort OCPD with less than 250mm 6mm cable in total on the internal LNE SPD cables. For an extra £3 a 32amp mcb can be added to supply the SPD to give protection aswell ?
Hi Ian,
My issue is continuity of service, if an SPD relies upon the dno fuse and for whatever reason it shorts out then you will loose the total supply and will be non compliant.
The extra £3 for mcb sounds okay tho.
TBF, that’s a good point and totally agree Ian, Fitted one earlier this week with SPD and personally did opt for the 32a mcb as was a 100A supply fuse , may consider this for 60-80a aswell. Also fitted an AXIOM earlier this week with SPD and manufactures instructions required ocpd via mcb, maybe fusebox will require this soon aswell.
but to answer the ops question , the brand is an option with type A rcbo s and type 2 SPD , ( with optional mcb ocpd ) and is a good build quality at a reasonable cost . ??
It really depends on the SPD whether it needs an OCPD.
Its my understanding that SPDs are designed to fail open circuit. Pretty sure they are manufactured with a small soldered joint which is spring loaded, this is designed to melt under high fault currents and break the contact.
I was going to look inside one, to see exactly what is inside, but can't seem to open the plastic casing without risking damaging it (it is in a new Fusebox CU yet to be installed).
Reply to Only 2 brands for domestic type A rcd/rcbo + type 2 spd in board?? in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi all, With Amendment 2 here has anyone found any good suppliers for SPD and RCBO domestic boards? I've found online a BG SPD + 8 RCBOs for...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
