Search for tools and product advice,
Discuss osg tables in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
HI there this is my first post. im sitting my ACA soon and found all your posts very helpfull. Im having a few probs tho. When doing your ze if its 3ph do you test each and take highest result or an average or do you just test one phase and where is the table in the osg i compare the results to, i cant seem to find it(am using 17th the green one).another prob is the rcd results a cant find them either( am rubbish) a no what the rated tripping times are from reading your posts but cant find them in the osg.i would like to know where they are incase am asked to point them out. help would be great as i seem to be going round in cricles.
Your ZE would be useing one of the phase conductors and then have a look at page 11 in the OSG.
Remember it depends on your Earthing of the premises when you look at the result!
RCD results have a look at page 106 !
rcd main switch that is, sorry. some people are saying 30ms.
If you have an RCD as the main switch then there is no difference from having an RCD anywhere else.
The tripping time depends on the type of RCD for a 30mA BS4293 the tripping time at I⌂n it should <200ms, for a BSEN61008 or BSEN61009 the tripping time at I⌂n it should <300ms, for a BS7288 the tripping time at I⌂n it should <200ms.
For a 30mA RCD used as additional protection then the trip time at 5I⌂n should be <40ms.
Reply to osg tables in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Now Ive done Periodic Inspection and Initial Virification Qualifications with LCL/EAL (so non C&G 2394/95) # strange part building Modules , this...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Electrical Courses
