Discuss Outside light - signing off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Paul Downham
Good morning all,
I have been asked to fit an outside light for somebody, it is not a replacement but a new installation so I need to find a feed and so on.
I have no problem in doing the job but I am not sure how this fits in with the certification side of things. What do I need to do in terms of providing a certificate?
I am 2330 & 17th edition qualified but am not registered to elecsa or NICEIC etc..
Regards
Paul
Out of interest, your posts from 2 years ago suggest you were doing notifiable work - so what did you do then?
Hi,
I was working alongside another electrician that could notify. I am working alone now although I have been inquiring this morning and understand that I would need to sign up with elecsa/niceic etc. or inform building control for an inspection.
Unfortunately, I do not work as an electrician full time and as signing up costs around £500 it may not be cost justified. Any suggestions?
Thanks for the reply.
Paul
Hi,
Paul
Stop doing cash moon lighting jobs?
Thanks for the support Murdoch.
I am working on a large country estate in Essex. It's my 1st job since being made redundant from a bank I worked at for 20 odd years and I am working as a painter/decorator/carpenter/electrician. I have a family and a mortgage to pay and in the current climate I need to work.
I am paid by cheque and put it through the books. I studied at college evenings to gain my electrical qualifications and was after some advice really, although from your reply I wish I hadn't bothered!
Cheers
Paul
Fitting an outside light on the outside wall of the house with no exposed outside connections is not notifiable to building control, so long as it is not a new circuit.
For BS7671 certification you can print the model forms from BS7671 and use those.
Thanks Richard,
I just called building control and they confirmed the same. I will sign up with Elecsa or NICEIC for the sake of completeness as the place I am working are asking for more electrical work.
Thanks again
Paul
go for elecsa, they are cheaper and more "electrician friendly". as richard just said, if it's not a new circuit, then it's not a problem. as from april 6th, less work will be notifiable. basically, all that will be notifiable then is 1. new circuits. 2 CU replacement. 3. any work i bathrooms/special locations.
Only work in the zones is notifiable in the bathroom from April 6th (unless a new circuit of course). Whether this is a good or bad thing remains to be seen!
Thanks Richard,
Thanks again
Paul
Go with Elecsa and use the install for your assessment. Jobs a good un!
WTF is "signing off" ???
you either issue electrical certificates or you issue building notification , or both.
anyway does anybody even bother notifiying a poxy wall light these days ?
all that effort and paperwork for a local authority that almost certainly doesnt give a crap about a new light in your garden ?
cant we go back to paperfree cash backhanders ? life was simpler then. :-D
Reply to Outside light - signing off in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
