- Reaction score
- 5,467
I usually fit outside taps with plastic pipe through the wall. OK, it's not flush, but you simply use a 15mm compression elbow, then a short length of plastic pipe to another compression fitting into which the tap screws. The bib fitting needs to be spaced off the wall on a piece of wood. The whole assembly is more resistant to frost, and i fit stopcock internally, so when winter comes, switch off, take tap away, exces water drains out...and in Spring, it's 2 minutes work to re-assemble.
[automerge]1587506056[/automerge]
[automerge]1587506090[/automerge]
Compression fittings on plastic pipe are your friend!
[automerge]1587507283[/automerge]
Here's a pic...on this occasion I used a copper "stub" pipe, but the pipe through the wall is plastic. It's mounted on a chamfered teak backing plate. To me, it just makes sense to have a plastic pipe through the wall, and internal coupling is easier.
