Discuss Pendant Cable Grip in the Lighting Forum area at ElectriciansForums.net
Strima
Anyone know where I can get some pendant cable grips as I loathe having to replace a whole pendant when a couple of pence on a bit of plastic would suffice.
One the three plate and I can use a small cable tie but the lamp end they are too big.
And no it’s not on the floor, my phone was the wrong way round...
If the cord grips have snapped off then you need to replace the ceiling rose.
I don't think I've ever seen the red bit in a ceiling rose before, all the ones I've fitted just had the two pegs to wrap the cores round.
i just fit a cable tie in it's place. however, these grips are a recent innovation and before we relied on the flex being wrapped around the lugs in the rose base.
That's the bit I was after, they are a good idea as the strain is taken by the outer sheath but the plastic becomes brittle over time and breaks.
This is a common method in Spain, all the weight is taken on the hook/plastic restraint. A plastic "rose" slides up the cable to cover the hook and cable entry hole.
Ideal for heavier fittings.
These damn newfangled things from the 90's, such a pain! :D
Reply to Pendant Cable Grip in the Lighting Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi everyone, I'm hoping someone here can help. I recently did some carpentry work for a new customer and I noticed their electrician had just...
I having been trying to make a cart wheel chandelier for my wedding in July like the one in the photo attached. I have 31 lamp holders in mason...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
