Discuss polarity test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
K
KillerKlown
Hi, I have just done a IEC check. It is a normal plug plugged into the mains, then on the other end, it's been wired up to a double socket. It passed the earth, and insulation but failed the polarity test. Im gathering that means its not wired correctly and needs to be taken out of service until repaired?
if the socket has been added DIY, it's probasbly wired incorrectly. either fix it or take out of service with a red fail sticker.
Yes it is an extension. Either way. I failed it. I took the socket apart and re wired it but it didn't work. It looks like a DIY job to me.
Reply to polarity test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Insulation test live to earth = 0.7 ohms. This is a long length of buried swa cable (approx 100m) from mains in to submain. Test done with live...
Hi Guys After bit of advice please as we don't do much data normally, tend to sub it out. Had garden building this week which we'd run in SWA...
Performing the PAT inspection on some science equipment and I have found some items that were passed by the previous company that performed it...
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
