M
ma701ss
Hi, would appreciate some advice please, I'm not a sparks. I'm dealing with a refurb on a warehouse with three WCs and a total of 6 electric showers (2 in each WC) to be installed. They're unlikely to all be used at the same time but it's possible. Also in the warehouse there is a large industrial sized boiler of some kind, unsure what it does, but it's about 2m x 2m x 2m in size so presumably draws a bit of power. However been told by the electrician that the power supply isn't adequate to run the showers. I don't know yet if he meant the existing supply to each WC isn't adequate to run two showers, or if it's the total number of showers (i.e. 6) that's a problem. Is this likely an issue with the supply to the building, or an just an internal wiring issue? Basically can it be sorted out potentially by running a separate supply/circuit to each shower? A megaflo is an option but most of the time all showers will probably not be used very much, and it will be a headache to change things at this stage now.
