Discuss rcd trip in the UK Electrical Forum area at ElectriciansForums.net
shared neutral ( on 2 way lights, usually). both RCDs see an imbalance because the suspect fitting takes L form 1 RCD and N from t'other.
do your continuity tests etc, IR test between circuits.
cheers tel , doesnt take long for the wolfs to pounce , still learning boys , dont do much domestic work or testing , as said someone took a N from the lights.
Every days a school day!!
So everyday might be a school day, but this is so basic, you should of tried to sort it first and then if stuck ask, but come on if you are out there working as a spark and asking these simple questions, you are not competent enough to go out and work on your own or perhaps I've got the wrong end of the stick and you are doing a bit of DIY?
lol a take it on the chin mate , but a couldny work in houses all day , everyone i have worked on , the wiring is a disaster , my heads done in
Reply to rcd trip in the UK Electrical Forum area at ElectriciansForums.net
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
