- Reaction score
- 0
I have 3 locations that have a relay controlling a pump, each site is several miles from each other and when my SCADA system calls for RUN all three relays energize at the same time. What I need is a local control that allows only 2 pumps to run at the same time but they need to alternate, (example) 1&2 when called then 1&3 on next call then 2&3 then back to beginning. Each site has a 12vdc relay interrupting the Auto of a selector switch, I was thinking of alternating relays for the control circuit but would like help in a wiring diagram showing this solution.
