Discuss Replacement in the Lighting Forum area at ElectriciansForums.net
Hi guys ,looking to replace a anchorn AET-635CT1 transformer in my light to a compatible LED driver ? It’s a round transformer with a hole .Any advice would be appreciated.
Cheers
John
TL;DR
Replacement?
What kind of bulbs does your fitting take, and can you get LED as replacements?
you might just have to get a small rectangular transformer/driver and have it tucked into the side a bit. Not sure you can get a driver that exact shape, but you could try the manufacturer?
Did something similar, used I think they were Aurora round LED Drivers. Others are sure to make them too or as previously said a small rectangular one will probably fit!
Reply to Replacement in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
