Discuss Replacing standard switch to smart switch in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I am looking to replace my bathroom switch in my flat for a smart switch.
The switch controls 4 downlighting and the extractor fan. The extractor is also controlled from a separate switch in the kitchen. I.e two ways
below is picture of the old switch wired up.
Supply side has 3 brown lives in L and another brown in N
Load side has a switched neutral in the N and another brown in the L
The rest of the neutrals and in an block in the back box.
The new switch has only 1 neutral, an L and a L1.
I cannot for the life of me figure it out.
Am I stupid or Will this new switch not work?
any help is massively appreciated. Thanks Aaron.
Im not understanding how your extractor fan works. If it was two-way, ie can be operated from either switch, there would be 3 cables coming from the switch just for the fan.
Do both switches (kitchen and bathroom) need to be on for the fan to work?
You may not get a double pole smart switch... but you could get a 2 gang. So each switch on that plate can be turned on individually. Light on or fan on, or both, depending how you program it
as above. the neutrals are the blues in the choc block, not connected to the switch itself.
Yeah that’s what confusing me aswell.
Nope either switch can be on for it to work.
It’s a new build and I’ve noticed a lot of the wiring seems to be a bit unconventional…
That’s a good idea though, just get 2 gang version instead.
That could be the case with two single way switches in parallel (bathroom and kitchen). Either can turn it on, but both need to be off for the fan to be off. Is that the case here?
It doesn't look like a two-way switch to me.
2-gang smart switches typically have a common live in, and give a switched live out for each gang from that common source.
Here we have a two gang switch, presumably for a reason (?) so need to be sure there's not two seperate circuits in play. Basically, for the 2 gang smart switch option to work, you need to be sure both the lighting and fan are, or can be, fed from the same circuit, ie from a common live.
Reply to Replacing standard switch to smart switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I want to install smart light switch into the wall socket that currently has a normal light switch. The smart switch requires a neutral wire which...
I'm trying to replace this standard 2 gand 1 way switch with a smart switch. I've put the both live wires into L in and the switched lives into...
