Discuss Replacing transformer on lamp. in the Lighting Forum area at ElectriciansForums.net
Craven
Looking to replace a broken transformer on lamp. Having problem finding the exact part. Transformer model is CY35-2400150A 12V 60Hz made by NingboChen Yow. I can find these transformers, but the one I need has a female outlet that the cord plugs into. The lamp has a male plug.
I'm in the UK so of limited help 🤪.
I see these particular transformers for sale through Amazon and eBay etc.
Some ad's show male connectors, some show female, and some show pics of male plug but the sale includes an additional spare female to female lead. And many ad's hide the output connector deliberately so you have no idea!
Maybe persevere with the search. I found deleting the hyphen from the part number broadened the Google results!
Or you could buy the transformer with the wrong connector and change it!
Or as above, and buy a female to female coupler/adapter!
Reply to Replacing transformer on lamp. in the Lighting Forum area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hi, DIY’er here. I need a replacement transformer but can’t find the exact model required anywhere. It is Golden Power GP-SW120DC0700(UK)...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
have a set of lights that i would like to use plug over battery. have a few plugs and old sets with cables could Frankenstein together if doable...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
