B
Buckeye5316
I have installed a couple lights on my truck and have a rocker switch set to both there is an inline fuse and a relay in each circuit. For my front light bar I had it working perfectly. i then re routed some wires to clean it up and connected it to the battery. No matter if the switch is on or off the lights are always on. This was not the case before i rerouted everthing. I did not bump or touch the switch since it was working perfectly fine before i rerouted it all. The only thing i did was remove the battery connections and now my switch does not want to work properly.
