Discuss S Plan Help in the Central Heating Systems area at ElectriciansForums.net
I had this the other week, converted y plan to s plan to introduce UFH easier, but upstairs rads came on with hot water, turned out to be a plumbing issue with rads plumbed after hw valve.
Turns out the zone valve base was faulty. It was brand new fitted yesterday. Swapped for another new one and everything is working as should now. [emoji106][/QUOTE
i physically let out a sigh of relief for you. We've all been in that situation when you think you've done everything to finish a job and for some reason it doesn't work.
New posts
Reply to S Plan Help in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi does anyone have a S plan wiring diagram that incorporates a third zone to accommodate an underfloor heating system like polypipe? Would...
I had to wire in an extra 2 port valve today to protect a newly installed unvented cylinder (replacing the old gravity fed one) in a standard Y...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
