Discuss S Plan Plus Heating System in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
S
snipes
hello,
just been looking on the net for a bit of support on this matter as i carnt get in touch with honey well or vaillant about it . then came across this site and thought i would post ! so hello to all .
iam a qualified electrician wanting an answer to a question on the title above .
the boiler is a vaillant eco tec system it requires a live feed at all times fed from a fuse spur the there is 3 control terminals 3,4,5 . 5 is spare neutral so not bothered about that . 4 is switch live from terminal 10 on wiring block and orange wire on the valves, but what gets connected to 3 ? nothing ? perminate live ? and if so can this be linked form the live feed ? not done many system boilers always seem to be combi
thanks in advance for the replays
this is the wiring diagram for a s plan if it helps
Hi there
do plenty of boiler wiring, friend is b****y plumber he actually gives me plenty of work!
I often have to provide a permanent live for frost stats on outside boilers etc.
I take the permanent live after the 3 amp fused spur which feeds the ten block connector on terminal number 1. of connector block 3. on your drawing is usually the earth connections
Hi all... Do quite a few s-plans. Majority of boiler manufactures recommend you take your mains to boiler first. Then terminal 3 is perm live, terminal 4 is switch live and termnal 5 neutral. Isolation to all external controls time clocks and valves can be turned off via switch on boiler front.
System boilers external switch contacts are exactly the same as a combi boilers (usually:) )
Good thing to remember on 2 port valves, whether its upstairs, downstairs heating and underfloor heating is to join all greys together, all oranges together. Then use brown on valve from switched live signal (ie room stat) to switch the valve. All the brown does when made live is open the valve and makes a ciruit between orange and grey(micro-switch).
Some boilers 3 and 4 so to speak operate at low voltage (ariston).....These two port micro-switches
(grey and orange) can switch at low volt, but brown still needs to be switch signal at 230volts. This is not ideal on the valve flex having these different volages. This info was from ariston technical( the boiler in genral wasn`t any cop)
Bit of a mouthful that!
thanks for the replays , i mignt not have explained myself very clearly
all the wiring on the system is in and all the controls are working fine , all my question is , when you take the link out of terminals 3 and 4 if you look at the diagram you just have a switch live coming from terminal 10 on the connection blocks. so if you connect the switch live to terminal 4 is that it ? dont you need anything connected to terminal 4 ?
the whole of the system is 240v there is no low voltage or no volt contacts
this is the link for the user guild page 28 http://www.vaillant.co.uk/stepone2/data/downloads/d7/42/00/839592_09.pdf
the diagram is not quite right as it has an external pump and the pump is inside the boiler in the vaillant thats the bit iam unsure about
thanks
Number 1 on your 10 way block to number 3 on boiler (remove perm live)
Number 10 on your 10 way block to number 4 on boiler
Hope this helps
thanks you for quick the replay
can you just link the live in the boiler to terminal 3 ?as that is just the same as terminal 1 and is disconected from the same dp switched spur
Hi..
In an ideal world your live feed to your valves should be terminal 3. If the wiring is already in place just put that switch live into terminal 4 on boiler from number 10 on your wiring box and don`t connect anything into 3 and 5.
Good luck.
Generally speaking what Size cable would you use for an S plan heating system? I know you would run 2.5 from the D/B to the Spur feeding the system. Would I use 2.5 for the rest of the system?
Cheers
Hello,
I use 1.5 for the whole install ,even the supply and back it up at the dis- Board with a 6a the boiler usually requires a 3a bs88 fuse so why supply the spur with 16 of 20amp when it's not needed. saves on cable too.
I know this is a bit late to help Snipes but here is an explanation and wiring diagram about wiring S Plan and central heating boiler systems. Wiring Diagram for S Plan Zoned Central Heating Systems | Electrician's Blog It may be useful to someone else in the future. All the best.
Reply to S Plan Plus Heating System in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
