Discuss s plan with megaflow in the Central Heating Systems area at ElectriciansForums.net
stidge
Hi all, system is as above, have a es-ctd cylinder stat with c,1,2. whats confusing me is all the schematics show this stat with y plan. ie with an extra cable from programmer hw off which links to satisfied on cyl stat !! do I need to incorporate this or just wire as normal s plan into cyl stat using common and 1 or 2 ? please help
yes robspark , but as theres a megafow cylinder do I not need to wire the stat (dual) as I believe it has fail safe for overheating ? or am I talking bo***cks ???
Using C and 1 means that stat will stay on until up to temperature and then switch off.
Using C and 2 would mean the stat would come on when the set temperature was reached.
In either case if the limit temperature were reached the over limit would switch the stat off.
Reply to s plan with megaflow in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I had to wire in an extra 2 port valve today to protect a newly installed unvented cylinder (replacing the old gravity fed one) in a standard Y...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi guys, Do you know if I can install a Nest E with the heat link in the airing cupboard as opposed to the room stat position? System is a S plan...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
