J
Jesta
Hi.
Looking for some advice.
I have 2 lights, both with a Schuko plug (16a 250v) which I need to rewire and use on a UK plug.
The wires are non polarised so only 2 black cables. I have been advised that these don't need to be earthed and doesnt matter which connect to live/neutral although I will be fitting the appropriate fuse for each.
The thing I wanted to know is if this is correct and can I then plug this to a dimmer switch and then to an extension plug?
Light 1 15w, so will use a 5a fuse.
Light 2 30w so will use a 10a fuse
Dimmer switch is 230v rated at 300w.
If not how best can I use this set up. Unfortunately using another cable is not an option given it has a unique connection to the light.
