M
Murdy
My pal has asked for a power supply for lights and sockets in his garage and so can I just ask if the following would be ok ???
32A MCB at the main CU to protect garage feed.
2.5mm SWA run of 30m to the garage
Secondary CU in garage with 1 20A radial for 3 socket outlets and 1 6a lighting circuit.
considering volt drop over this length would I need to up the SWA to 4mm or should 2.5 do ??
cheers
cheers
