Discuss size of earth on 16mm mains tails in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size with this 16mm or 10mm ? Thanks
If you are referring to the typical UK insulated and sheathed singles used as meter tails these don't include a protective conductor in the cable. The norm would be to run a 16mm^2 Earthing conductor alongside.
ye if it was a 100 amp main fuse i would install 25mm double insulated tails with a 16mm earth, so if it is an 80 amp fuse then i know i can use 16mm double insulated tails but is a 10mm earth sufficient or does it have to be a 16mm?
If selected (as opposed to calculated) then 16mm^2 is required. As I stated, 16mm^2 is the norm.
so cpc being minimum of half the live conductor size does not apply here then?
No, see table 54.7 in the regulations for the full story.
If you are using the table 54.7 method of selecting a protective conductor size then for a line conductor of 16mm,25mm or 35mm the protective conductor needs to be 16mm.
This depends on a number of factors.
If you are using the table 54.7 method then it will need to be 16mm.
If, however, you are calculating the size required then you may find that 6mm (or less) satisfies the adiabatic equation. But you also need to consider the earthing system as this will affect the size that the earthing conductor needs to be to satisfy bonding requirements.
Reply to size of earth on 16mm mains tails in the UK Electrical Forum area at ElectriciansForums.net
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
