- Reaction score
- 8,899
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online.
I've taken over a job that's used 16mm twin and earth (along with separate 16mm CPC) as a distribution circuit.
While I can arrange for most of it to be clipped direct, there's about 4m that is going to have to be chased in, and I don't want a 30ma RCD at the origin.
So I'd hoped to find smaller galv trunking.
Failing that, would a normal galv trunking lid screwed over the chase offer sufficient mechanical protection?
If not I guess I'm into cutting up 2mm mild steel sheets.
Bright idea's welcome.
None of this is what I want, it should have been SWA, but I can't justify replacing the whole cable because of this 4m problem.
(It's also a very horrible situation, and I'm keen to get this done asap. I'll explain more in the arms later)
