Discuss Solar PV ground fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi guys.
Got an issue with a DC string ... I am doing some DC testing and one of the strings is 0.5ohms (negative to earth). Positive is 29mohms and rising to earth.
Now usually I would expect to find a crappy mc4 or a damaged cable but this time I am on a farm where all the cable is visible and looks ok.
I have disconnected the pos and neg at either end of the string and now when I test to earth at the inverter location it is clear? Tested all the panels to earth and they are clear.
I suspect it is the cable but why is it testing clear when disconnected from the panels ?? I am getting into the solar a bit more and have some more questions in the bank for future posts :) hope I can find somebody in the no....
Many thanks
dB.
Could it be a faulty panel connector? Have you tested the panels?
P.S. I know nothing about PV panels so a complete guess.
Reply to Solar PV ground fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi Guys, Currently on a 3MW Solar farm job and will soon be coming up to the testing stage of the project. My question is, where do you do your...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
I have a small Pv farm 5KW. Some months ago inverter started to measure low Riso<1MΩhm (0.8). I tried to test each string alone and with one the...
Hi installing my first solar PV on my own home before starting the courses next year and need some advice on earthing PV. System 6kw solar PV - 2...
7K
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
