Discuss SOS/ fire alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Could anyone help me wire this, have 17v to 60v sos light and beacon so have power supply feed this and I need to wire this micro switch so when the door opens the light and beacon come on?
The switch connections will depend on where you put the switch. If the switch is put on to the frame and will be pressed when the door is closed then you want to wire across the NC terminals. If you put the switch on the wall so that it is pressed when the door is opened then you need to wire across the NO terminals.
Hi I want it so the door is closed (pushed in) and once opened the beacon and light with make noise and light
Reply to SOS/ fire alarm help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
Hi All, Please may I ask if light fixtures must now always be fitted by an electrician? also for domestic homes, is it okay for there to be a...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
