- Oct 1, 2019
- 5
- 7
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Greetings ladies/gents. Any advice on the following. avid diyer I’m afraid.... on plans to move rad pipes under the floor upstairs I also decided to place some more sockets in the bedroom ( only 2 at opposite sides of room) since then lifted floor boards and discovered they are spurred off the sockets below. Now my question is this. I’m quite happy to add a ring to the upstairs and feed it down to the consumer unit. Also happy to terminate the old wiring in wago boxes or junction boxes under floor And disconnect from ring sockets below where possible Would this be acceptable to your ears. One more thing. Am going to ask would a spark add a isolator from meter tails or would this be the meter supplier... I’m happy for him/her to test my work too I do like to be tidy. Anyone have any views..
