Discuss Step up and Step down transformers in the UK Electrical Forum area at ElectriciansForums.net
P
PLW
Hi guys I am currently training to be an electrician and have only been at college about 6 months. So my understanding of things isn't particular great.
Anyway I have recently come across transformers and whilst I understand the general idea is to either increase or decrease the voltage for a circuit, would I be right in saying that step up transformer increases the voltage and therefore increases the current, and that a step down transformer decreases the voltage and therefore decreases the current.
I got this idea from Ohm's law - The level of current flowing rises if the voltage is increased and falls if the resistance is increased.
All help is appreciated sorry if this isn't very technical :)
Hi - If voltage goes up (step up) then current will go down. If it didn't, then there would be more power out than was put in.
Ignoring transformer losses
input volts x amps = volts x amps output
240volts x2 amp =480VA= 12v x 40amp
VA =volt amps
Stepup means to go up in voltage and down in amperage
Stepdown means to go down in voltage and up in amperes
Assuming you are talking isolating transformers a step down has more windings on the primary input side than the secondary output side. The current from the secondary is proportionate to the primary, so if the step down is 10:1 for the voltage the current output is a 10:1 step up. The reverse for a step up transformer.
Thank you for your answers guys. So now I know that as the voltage increases the current decreases and vise versa. So why when Ohm's law states that when voltage increases current increases, is it the opposite for transformers?
Without doing the physics (lazy me) - if it wasn't this way the transformer would be magically putting out more power than was put in.
if you increase the voltage across a resistor, say, then the current will risebecause I=V/R according to ohms kaw. however, with a transformer, your load may be 10 A @ 24V wich , as power in =power oot, means @ 240V the primary current will be 10A x (24/240) = 1A.
So in very basic terms as the voltage is stepped up the resistance is also stepped up causing the current to decrease vise versa
no. you're looking at this from the wrong angle. look more using the simple formula P=IV. ignoring any losses for simplicity.
As telectrix said you are looking at it wrong. Don't use ohms law in the way you are. Consider that ohms law applies to either the input circuit (the primary winding) our the output circuit (the secondary winding). V = IR applies in the primary and V = IR applies in the secondary winding, independently, with R being the resistance of the winding/coil. What you are confusing it with is thinking it is one circuit, its not, think of it as 2 circuits, the primary winding is one, the secondary winding is one. You are right that if the voltage increases in the primary then the current will increase in the primary.
Using P = IV, for a 100% efficient transformer power on the primary winding will be equal to power at the secondary winding.
So lets say you have a transformer with 230v, 2A input and 12v output.
Pin = Iin x Vin
Pin = 2 x 230 = 480W
So as we said 100% efficient so you know there will be no power loss so you will have 480W at the secondary winding and we know we have a 12v secondary so....
Pout = Iout x Vout
480 = Iout x 12
Iout = 480 / 12 = 40A
So as you see the voltage went down and the current went up.
Hello,
Upon visiting the site and performing some testing and inspection it has been found that all four of the CT’s installed in the starter cubicles are over heating. The burden is 2.5VA , ratio is 20:1 A @ Class 1 CT.
What might be the problem? Please help
What currents are/is the cubicles taking? there will be some heat produced, what makes you think the CTs are OVER heati?ng
Each cubicle takes up to 20A. All the CTs are damaged;
Reply to Step up and Step down transformers in the UK Electrical Forum area at ElectriciansForums.net
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
Hi there im in training, but my question is using using a 3 phase 480v delta to 208/120 delta transformer 30kva and wiring it in reverse for 208...
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
If we had 4 appliances to power, one in every room of a house, Once the current passes through them all, the remaining voltage & current is said...
