Discuss Suspending wires on ceiling? in the UK Electrical Forum area at ElectriciansForums.net
Vortigern
I am about to start wiring two flats from scratch. The builder board the ceiling and make it fireproof my first fix will be to this ceiling. Then they suspend another ceiling under that by 150mm with accoustic/thermal so my wires will be inside that. I am planning to use metal plastic coated strip and loop them on the routes. The question being how do you do it, is there a better way?
Hi @UNG, yes thinking about that. Is accoustic thermal (I guess so) and it is above plasterboard (100mm) then the cable touching plaster board on top of another layer of accoustic (100mm) Trying to figure out if that counts as "surrounded by thermal insulation" Assuming the worst anyway and using the rule of thumb applying a 0.5 downrating factor.
Reply to Suspending wires on ceiling? in the UK Electrical Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
I have an old IKEA Norrsken 12v suspended ceiling tension wire system, which runs x7 20w MR16 bulbs, from a Min 4x20w/Max 10x20w transformer. Can...
