swa
Discuss swa in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If by brass ring you mean the banjo; this is used for connecting the gland to earth, run a cable from this banjo to the earth bar/terminal in the panel/CU
As for the shroud, the only purpose I can think of is for a neater job
The shroud is just to protect the gland a bit from the elements or any other substances that could possibly cause corrison , the banjo is for connecting the gland to earth and the olive is for making sure the armour has a tight connection round the gland
Just a thought, if we didn't put an earth cable inside the dis board (which we never used to as we just bolted the banjo down)is there any point in having the banjo, let me explain my thought, if the gland is tight on the casing then we have a good earth so dont need the banjo, if the gland is loose we dont have an earth and the banjo is useless anyway. Also, MEM have told me their casings are as good as installing an earth from the banjo to the earth bar
Reply to swa in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SWA
Is it possible to put a 16mm swa on a 40a mcb protected by an rcd
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
