Discuss Swap out Extractor Fan in the UK Electrical Forum area at ElectriciansForums.net
Segandy
Hi all.
I’m looking to swap my old noisy bathroom extractor fan for a new one and am after some advice on the wiring.
My old one is on a timer and comes on with the light, turns off after around 2 mins.
The new one doesn’t have a timer (it’s next to a bedroom and just a toilet).
The wiring is a Red, Black, Yellow & an Earth(not used), the old fan has 3 terminals for these to wire into.
The new fan has just 2 terminals.
Im guessing one of the wires is a switched live? And if so, how do I wire it into the new fan so it comes on & off with the light switch?
Thanks in advance
Andy
isolate at Fuse box first. blue into N. the switched L willl be red or yellow (probably yellow) into L. terminate red into a choc block or wago on it's own. if that's right, when re-energised, it will work with light. if it comes on all the time, swap red and yellow.
Perfect!
cheers
Reply to Swap out Extractor Fan in the UK Electrical Forum area at ElectriciansForums.net
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
