Discuss Switch wiring advice (smart switches) in the UK Electrical Forum area at ElectriciansForums.net
Davidh89
Forgive me for my lack of knowledge :)
I'm wanting to replace all of my light switches with smart switches, I'm award I need neutral wires for these to work.
I had a full house rewire 5 years ago so I pulled back one of my switches today to take a look.
Not sure what wire is what.
Any help would be appreciated.
Any advice on fitting smart WiFi switches over RF switches?
A few issues here.
1. Yes. You may need a neutral. (I say, "may" as some do not need a neutral to operate) The blue wire into the connector (and the grey with blue sleeving) is a neutral.
2. You also need a permanent live. You would have to test if you have one there or if this is the 2-way switch strappers and a switched live rather than perm live.
3. There may not be enough space in the back box for a smart switch. All the electronic gubbins takes up a lot of space. It depends on the make you go for
Thanks guys,
That's probably the biggest issue as it will be solid brick behind the box, so very difficult to dig out. Unless I use a spacer on the outside..
Reply to Switch wiring advice (smart switches) in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi everyone just looking for some advice before buying stuff not planning on carrying out this work myself will get someone who knows what their...
